i hate noises!! help me
Old Apr 20, 2006 | 09:48 PM
slottieskim's Avatar
Default i hate noises!! help me
i jsut got a 00 civic ex 5 speed about 2 weeks ago... it came with an a/m intake. and the little vacume port where the intake vacume hose should go there was a breather. now the brether was coverd in oil and tere was oil around it on the valve cover... it ran smooth and no real noises i could hear. i removed the breather and replaced the vacuume hose and about 2 or 3 days later it starts making noises... when i accelerate in any gear, when i get about about 3.4 grand in makes kind of a whistling noise and then stops when i let of the gas. is this ok? normal? or something could be wrong... also just noticed when i got home from work i was makin like a (damn this is stupid but its the only way i can explain it) "sicka sicka sicka sicka" but fast and real close to gether in idle. any have any ideas??? i could really use some input on this... thanks
Old Apr 20, 2006 | 10:15 PM
AgentofDarkness's Avatar
Default RE: i hate noises!! help me
Is there any oil on the air filter? Usually when you find oil on the breather hose, the PCV has gone bad or there is a clog somewhere. While the engine is running, pull the PCV valve out and check for vacuum. Then flick the PCV valve and listen for a rattle. If the rattle is there but the vacuum isn't then there might be a clog in the PCV somewhere or the PCV could also be bad.
Old Apr 20, 2006 | 10:24 PM
damn... i jsut got a car... i dont kno too much about the pcv valve... i only know breaks and steering. is there anyway you could enlighten me a little more? by the way thanks. ok and do you mean the air intake filter? no. i bougt a new one when i got the car. or are you talkin about the breather filter... becuase that was all gunked up so thats why i put teh hose back on
Old Apr 21, 2006 | 07:11 AM
Street Sniper's Avatar
Oil around the breather probably means the PCV like Agent said. PCV is Positive Crankcase Ventilation. It's a little elbow looking valve thingy that goes from the crankcase to the intake manifold.
The sicka, sicka is probably just a little Honda valve lash. My car does it too, but it's more like a "tick" than a "sicka". If it worries you , you can always check the valve clearances.
I suggest getting a Hayne's or Helm's manual.
Old Apr 21, 2006 | 08:58 AM
can the tick lead to eventual problems?
Old Apr 21, 2006 | 09:34 AM
and also this mourning when i got to the bank... there was water in teh exhaust...
Old Apr 21, 2006 | 06:04 PM
bump
bucklebabe
Aug 24, 2011 09:23 PM
rhondadahonda
Jun 6, 2011 11:27 AM
tyke
Oct 13, 2007 11:02 AM
StifflersMom
Dec 18, 2005 07:38 PM
clutchjunkie
Jul 12, 2005 04:00 AM
