Intake mainfold
I have a 96 civic hatch and i'm thinking about purchasing a intake mainfold and installing it but i will also need a new throttle body due to the one that is stock points upwards, my question is how much more horsepower wud bean expected gain. and what is a good intake mainfold and throttle body. I'm a newb that needs direction so feel free tocriticise except the fact that i cant spell criticise
I think it'll be a waste of money unless you get more work done to the engine. The runners on the intake manifold's are longer on aftermarkets like edelbrock and skunk2. This helps for more power in the higher rpm's, but then you will loose some in the lower....
What do you mean by the stock throttlebody points upward? Getting a larger diameter throttle body wont do anything but loose power. The diameter has to line up with the intake manifold's diameter.
These are usually lasts steps people add to built or boosted engines looking for a little more horspower out of there setups. In which case would be greater after being built for it. Haveing the head (part of the engine where the air enters through the valves, combusted and exits), intake manifold, and throttlebody, ported, polished, and matched all together, Allowing air to flow through uninterupted by bumps and bends.
ORIGINAL: Xirish3x
Yeah you can buy one and it would bolt up fine, but spending $300 plus for an intake manifold for a couple hp and lossing power in the bottom end is it worth it?
Your throttle body is not choking air at all for your stock setup (I get now what your saying the y7's throttle body's point upward). Those smart honda engineers did everything to these d engines to squeeze out as much power as possible, thats why bolt ons don't make much gains at all out of them.
What you could do if your civic is an lx or dx is buy a d16y8 intake manifold, prolly get one for $100 max, they are made very well. Haveing medium size plenums and decent sized runners.
I just don't want ya to get burned spending big bucks for brand names that wont do a thing but make your engine bay look nice. Save up for an engine swap or turbo. Much better money to power ratio.
if it were me, and i were only slightly modifying the motor, then just pick up a side entrance manifold from an 'ex' model or any d16y8 block. just use the mated stock throttle body as well. that mixed with an aftermarket intake will result in about 10 hp or so.
strtballer98
May 20, 2007 08:39 PM
RedLineCivic02
Nov 25, 2006 06:22 PM
FlipHKD720
Sep 21, 2006 09:29 AM
