Thermostat??
Old Jul 20, 2005 | 01:03 AM
sacicons's Avatar
Default RE: Thermostat??
usually when a water pump goes, it leaks all over the place. it sounds to me like its the thermo. a 160 thermo will only help if you get a mugen or spoon fan switch sensor as well. if the fan wont kick on till 180, then it doesnt matter if the thermo is open or not. also, if thats what you are doing, an aftermarket radiator cap is a good idea too. though its hard to justify all that (about 100-130 bucks worth) on a street car. temp isnt that big of a deal in normal use. youd be better off getting a bigger radiator for a little more money.
Old Jul 20, 2005 | 01:11 AM
ngoti 8tor's Avatar
I've seen waterpumps "go" without leaking. They usually leak when the seal goes since most of the manufacturers put a small hole on the outside of the seal so that when the seal leaks, coolant comes out the hole to let you know before you have a full-blown catastraphe. (Although I don't know if Honda puts that hole in for advance warning.)
Old Jul 20, 2005 | 08:22 AM
sacicons's Avatar
yeah they do. its called a "weep hole" i had that problem when i dropped in the b16. i finally got it running, backed it out of the shop for the test drive, and there was a line of coolant following me thats why i am always telling people to do that while its on the ground. ive been there. oh, and a couple of months later, my stock clutch broke. one of the springs broke out and jammed it up. so i made sure to take care of all of that on the new motor. havent had any real problems yet. *knocks on wood*
Old Jul 24, 2005 | 11:27 AM
93SiHb's Avatar
fixed the problem and guess what ? it was neither the pump nor the stat theres this lil bleeder on the top house housing on the engine if you opne it and fill the radiator the coolant goes in the engine and that was the whole problem now its staying soo cooollll about 1/4 up of the C
Old Oct 25, 2005 | 07:48 PM
ooxteme_DELETEDBYREQUEST's Avatar
what did u do when u bled it? does it release the air in the system? cause im goin through the same thing with my 93 ex
wrinkledpants
Dec 3, 2006 10:30 PM
trebor_2005
May 19, 2006 01:40 AM
dimaguila1
Mar 2, 2005 11:28 PM
StifflersMom
Feb 1, 2005 06:19 PM
scottk
Jan 10, 2005 09:34 PM
