thermostat install
Old Jul 4, 2007 | 07:36 PM
jc6711's Avatar
Default thermostat install
is installing a new thermostat tommorow for my first time. how hard is it and is there anything i should watch out for?
Old Jul 4, 2007 | 08:05 PM
drbyers's Avatar
Default RE: thermostat install
installing a new thermostat is almost as easy as installing new spark plugs. it's rediculous how easy it is.
but it's messy, and make sure you buy a tube of hondabond sealant or some similar silicone sealant to use when you put the new thermostat in.
and make sure you bleed the bubbles out of your coolant system properly when you refill the coolant. if you don't, your engine might stumble or surge when idling.
here's a bit of advice: don't let the antifreeze get all over your driveway or lawn if you own pets. animals will drink the coolant because it's sweet, but it's highly poisonous.
Old Jul 5, 2007 | 07:10 AM
jc6711's Avatar
ok thanks.
Mario89
Mar 11, 2007 06:51 AM
93SiHb
Oct 25, 2005 07:48 PM
dimaguila1
Mar 2, 2005 11:28 PM
StifflersMom
Feb 1, 2005 06:19 PM
scottk
Jan 10, 2005 09:34 PM
