timing issue
Old Jun 9, 2009 | 12:20 PM
candyman420's Avatar
Default timing issue
I took the crank pulley off and when i put it back on..I lined up the divit on it with the divit on the crank. Is this right???
Old Jun 9, 2009 | 01:19 PM
There is a key (rectangular metal block) that fits into a slot created between the crankshaft and crank pulley when they are properly aligned. Did you insert the key?
Old Jun 9, 2009 | 01:52 PM
the "key" must of fell off so my whole **** is still out of time....ty for this info....
Old Jun 9, 2009 | 01:55 PM
The mechanical timing is fine if you got it right when you installed the timing belt on the crank gear. You may be able to buy a new key from an auto parts store.
Old Jun 9, 2009 | 02:11 PM
im just gunna scan a magnet on the ground.... the car hasnt moved so it cant of gone to far...
Old Jun 9, 2009 | 02:19 PM
Old Jun 9, 2009 | 02:24 PM
the key..... should be able to fing it on the ground with a magnet..... then i should have a fully done mini me swap once i get this timed.... bad aples 89 crx si....
Old Jun 9, 2009 | 02:25 PM
Oh, gotcha.
mudhenFUF
Jan 16, 2023 08:43 PM
Sporange
Sep 24, 2005 06:22 PM
splman75
Aug 5, 2005 12:11 AM
JayMan
Dec 4, 2004 03:30 PM
