valve tick after adjustment
Old Mar 8, 2007 | 03:53 AM
jbum's Avatar
Default valve tick after adjustment
I did a valve adjustment (twice in fact after the first didn't quite satisfy me) and now I seem to hear slightly
more valve tick noise. Do you hear more noise when the clearance is greater (looser) or smaller (tighter)?
Also, I notice that when I turn the engine off, the engine stops sooner than I "think" it did before the adjustment.
My guess is that I had tight valve clearance and some of the valves were slightly open... leading to less resistance
on the cylinders with more blow by gas. Now with the greater clearance, the valves probably sit flush and cause greater resistance to the moving cylinders during engine slow down. Am I right?
jbum
Old Mar 11, 2007 | 04:53 AM
jbum's Avatar
Default RE: valve tick after adjustment
my bad. lookin at the manual, the picture was confusing and I adjusted the valves using the
clearance between the cam and the rocker arm. for my '93 dx, the clearance was supposed to be
based on the space between the valve and the rocker. i had another car where i had to adjust
the clearance on the cam and got confused.
Old Mar 11, 2007 | 10:33 AM
riceburner700's Avatar
yeah you have to do it on the other side of the rocker arm that pushes against the valve
Old Mar 11, 2007 | 03:23 PM
windcalmer's Avatar
Just be careful when your doing it and go loose if in doubt. LOL It took me three trys to get it right. So good luck.
07civic07
Jun 24, 2010 04:55 PM
98civex
17
May 7, 2008 10:18 AM
Essix
Mar 27, 2008 07:40 PM
BLKnight21
Sep 2, 2007 01:24 PM
chin_dude
Jun 4, 2007 05:40 AM
