Vtech question
Old Nov 26, 2007 | 05:02 PM
Civic the Knight's Avatar
Default Vtech question
I have a 96 honda civic with a autoD16Y7 motor. I wanted to know if i could make itv-tech by getting a D15B SOHC head. Will it directly fit with out machine work? Also whatelse would Ihave to do besides get a V-tech wiring harness and switch out the mass airflow sensor?Oh and one more thing, woulda D15B 5 speed tranny directly fit?
Old Nov 26, 2007 | 05:27 PM
jpnolan's Avatar
Default RE: **** question
doing a trans swap semms like it wont be that hard but do some research you need pedals ecu new shifter transmission fly wheel and some other stuff use the search feature and i think there are a few trans swap threads about the head it can be done but there are aslo some other things needed besides just the head again use the search it has almost every question answered good luck
Old Nov 26, 2007 | 05:32 PM
You also need to change the ECU to go from non-VTEC to VTEC. So you should do the trans swap at the same time.
lira_3689
Feb 1, 2015 04:08 PM
StonedCold
Oct 31, 2011 08:26 AM
guate2006
Dec 17, 2008 02:17 PM
baker
Sep 18, 2007 01:24 PM
ballinboy1020
Nov 21, 2006 11:45 PM
