zc isn't starting..code 4 and 10
Old Jan 1, 2008 | 08:37 PM
Hailchristian's Avatar
Default zc isn't starting..code 4 and 10
Well... its not starting..
dohc zc swap in my 88 std (DPFI)
here are my symptoms..
I have ECU codes 10 and 4...
i tried switching my distributor white wires...tried switching my CPS wires...
I have spark in all four cylinders. The engine is cranking but wont start..
fuel seems to be injecting..i had a leaky injector but i got new orings all around..fixed the problem.
http://youtube.com/watch?v=VqiWJU5qNOs
it also has a little bit of a tick to it...
any help would be appreciated [align=left] [/align]
Old Jan 1, 2008 | 08:55 PM
Default RE: zc isn't starting..code 4 and 10
What year Civic?
Old Jan 1, 2008 | 08:56 PM
1988 with a dohc zc swap.
Old Jan 1, 2008 | 10:04 PM
I don't think codes 4 and 10 would prevent the engine from starting.
Here are some potential causes for your starting problem:
1) Low fuel pressure and flow (pictures 1 and 2).
2) Engine timing way off.
3) A vacuum leak in a hose or connection (picture 3).
4) Problems with the throttle control system (pictures 4 and 5).
Old Jan 1, 2008 | 10:10 PM
alright..thanks ron..ill try these out tomorrow see if i can get it to start..
jdtrio
Mar 17, 2010 02:52 AM
kfreddy
30
Jan 29, 2010 10:18 PM
Street Sniper
Aug 22, 2005 11:19 PM
Street Sniper
Jul 27, 2005 05:51 PM
loyolarobyn
Nov 13, 2004 11:54 AM
