Help me deicide.
Old May 25, 2007 | 02:16 PM
Big T's Avatar
Default Help me deicide.
I've done the I/H/E. I've done a pretty good suspension setup and I've done someappearance. I don'thavethe moneyfor a turbo, I would but it would take forever.On my incomean engine swap is out of the question. I'm satisfied with the suspension and appearence, not with the power. I'm not sure if nitrous is good for a 9 year old car even if it's a dry shot. Please give me horsepower ideas.
Old May 25, 2007 | 03:19 PM
Chopsta's Avatar
Default RE: Help me deicide.
It's gotta be turbo, I know thats not what you wanted to hear obviously.
Piece your own kit together, all said and done should be around $3000.
Old May 25, 2007 | 03:47 PM
Kommando's Avatar
To get a little more quickness...
-Depending on what engine you have...Mini-me.
- Port and polish the head.
- Underdrive pullies.
-Tranny swap to get gearing more ideal for your preferences.
- Better clutch and a limited-slip diff for betterhookup.
- Short-throw shifter.
- If your exhaust still includes a stock-type cat, install a flow-through cat.
- If applicable, wrap the headers.
- Shave weight wherever practical. Get out and gradually work up to run 4-6 miles or swim 1-2 miles, moderately hard, every other day if you're a big boy.
Those are all fine for longevity and reliability. You could also try a more aggressive cam, but you may not like what it does to a daily driver if you go too aggressive on the grind. After that, a performance rebuild with a boring, balancing, and blueprinting could get you some power. It may mean premium gas though.
Old May 25, 2007 | 05:15 PM
ORIGINAL: Chopsta
For $3000 you could go with a pre-matched Greddy kit... I've heard a little over $1000 for piecing a kit together, but it really depends on where you buy from and how long you're willing to wait for a single part.
As far as power goes, Kommando has some good advice... also, regarding a cam: if you go with aStage I cam, you should be fine with driveability on the street, and they're usually worth around 10hp
Old May 25, 2007 | 05:20 PM
DonkeyBalls's Avatar
a 50 shot won't hurt
Old May 25, 2007 | 05:24 PM
mxs's Avatar
mxs
buy tires and go racing
https://www.hondacivicforum.com/m_398088/tm.htm
Old May 25, 2007 | 06:44 PM
Big T's Avatar
Like mxs said, I'll probably just start autocross. My car is will be pretty well set up for it once I get this freakin sway bar on. I heard a Stage 1 cam wasn't worth getting, but for basically the same idle and driveability with a 10 hp gain is not bad. What if I got a single fogger kit of nitrous or the NOS Sniper kit.The highest I would go would be a 50 shot. What do you guys think about a new I/M with a bigger tb and a cam?
Old May 25, 2007 | 07:00 PM
mxs's Avatar
mxs
ORIGINAL: Big T
then just stop, and spend your money on good tires, which will improve your car much more than the minor power gains you'd see from a new throttle body... cams and other internals bump you into a harder class, and nitrous isn't even allowed on site at SCCA events.
Old May 26, 2007 | 08:45 AM
Street Sniper's Avatar
I wouldn't even bother swapping to a Stage 1. I know the funds are tight, but how about the will? You could get some high compression pistons for ~ 100 bucks if you look around. 12:1 cr. Sweet. Honda Tuning put p28's in an otherwise stock z6 and made 146whp.
Old May 26, 2007 | 07:31 PM
Big T's Avatar
How bad would that kill my gas mileage. I'm willing tosacriface a decent amount fora goodgain.
stevenc
Jun 25, 2008 09:57 AM
redridinhood
Oct 9, 2006 07:27 PM
superballa22
Sep 18, 2006 05:06 PM
coolguy1234
May 7, 2006 08:31 PM
Jas10hon
Jul 4, 2005 10:35 PM
