$229.04 to install my exhaust system....
Old May 22, 2009 | 12:48 PM
  #31
enigma34's Avatar
donut gasket that came with header, dosint seem like it fits good with cat. thers a good size gap when cat is bolted, and the cat is a little slanted. do i need that gasket? what should i do?
Old May 22, 2009 | 01:55 PM
  #32
enigma34's Avatar
so i made it so it dosint tilt down, i used a box to hold it up so it has an epual fit around the donut. but is this space normal?
I hope somones on friday night to help me!!!lol
Old May 22, 2009 | 02:12 PM
  #33
enigma34's Avatar
so u hook up the o2 sensor's and the check engine light is still on. do i need to drive it around, or could it be the donut gasket?
Old May 22, 2009 | 02:37 PM
  #34
jprommel's Avatar
Angry Admin
try resetting the ecu
Old May 22, 2009 | 03:03 PM
  #35
ya reset computers memory.
Old May 22, 2009 | 03:09 PM
  #36
what space? i see no space
Old May 22, 2009 | 03:26 PM
  #37
enigma34's Avatar
how do i reset ECU?
In the pic the donut gasket is showing is that normal? the gap between the cat and header Thats what i mean space) i dont feel any air leaks around it.
Old May 22, 2009 | 03:30 PM
  #38
Are you talking about the space between the two flanges? That's normal... the donut is sealing it fine.
remove the ECU fuse in the under hood fuse box for a few minutes, and then put it back in. start the engine and let it idle for like 5 minutes. then you're good to go.
Old May 22, 2009 | 03:31 PM
  #39
to reset the computer just remove the memory fuse under the hood OR simply unhook one cable off the battery for a few mins.
Old May 22, 2009 | 03:33 PM
  #40
Or you could disconnect the battery, either way will reset the ECU.
E*d*i*t - Damn, addiction beat me to it
Also, are you not using spring bolts for the header-to-cat. connection?
