Ebay cat causing CEL?
Old Nov 11, 2007 | 04:01 PM
tools52's Avatar
Default Ebay cat causing CEL?
I just bought a DC Sports header, Apexi N1 cat-back, & Ebay high flow cat 4 my '00 DX. Ialso got a pair of O2 sensor wire extensions. After installing the whole system, the CEL came on. is this normal after installing an exhaust system, or could it be the high flow cat? could it be something w/ the O2 sensor? please help
Old Nov 11, 2007 | 05:35 PM
Mr Mobsta Man's Avatar
Default RE: Ebay cat causing CEL?
You could have broken an o2 sensor or more than likely the ebay "high flow cat" is really a test pipe/resonator and it is not really a catalytic converter.
Old Nov 11, 2007 | 06:04 PM
FlipHKD720's Avatar
ORIGINAL: Mr Mobsta Man
the second one for sure. The thing does nothing for emissions, you're going to need a simulator to get rid of that CEL (either that or a Magnaflow or Randomtech high flow cat, one that ACTAULLY is a cat)
Old Nov 11, 2007 | 07:42 PM
I like the spark plug non-fouler trick over a simulator. I think I have also heard that some people get away with plugging the sensor hole then just ziptieing the second o2 sensor somewhere out of the way in the engine bay and letting it hang.
Old Nov 11, 2007 | 08:22 PM
koots's Avatar
If you have a code reader, do what i do and just suffer through the CEL and just check for new codes periodically.
I am so used to CEL's from my 98 Sierra that now with my civic, i don't even notice.
Old Nov 11, 2007 | 08:26 PM
Pete's Avatar
Did you think to check what code its throwing?
Old Nov 12, 2007 | 06:08 AM
warner_ro's Avatar
it is not from the cat-back system, it is from the DC sport header. i got the instructions on how to turn off the CEL from procivic.com using there dorman "bung". just get the spark plug non-foulers from autozone, or some other store, and follow these directions., i did it, and once your done installing it, make sure you dis-connect the battery for a minute and then reconnect it and you'll be all set.
directions at - http://www.procivic.com/pages-produc...900/index.html
Old Nov 12, 2007 | 05:46 PM
Civic Si 00's Avatar
4 moths ago I installed a High flow Catalytic converter (magnaflow) On my 2000 Civic Si but I had to be OBD II Compliant CARB exempt In order to PASS emission test HERE in California [&:]
Silkwood98EX
Feb 12, 2007 09:26 PM
vaderslayer2000
Nov 13, 2006 09:32 PM
mentaldis0rder
Jun 13, 2006 08:02 AM
mill$civic
Sep 26, 2005 04:08 PM
shisso
Apr 4, 2005 09:15 PM
