need some help. big time
Is there anything left to grab? or they cut right down so they're flush now?
I would recommend trying to grab onto em with like vise grips or something and spray em with a bunch of penetrating oil and carefully trying to work em out. My experience drilling out bolts hasn't ever ended up too successful, they are hardend steel and forged in a way that makes the centres hard to drill out. It may be easier if you can heat em up with a torch or although if you're working in the bay you gotta be careful. If you are going to drill em' I would suggest going out and buying the best bit you can find for that purpose and start in small increments working your way up. They also make left drilling bits and extractors of sorts to help out...
Oohh.. I found a good page on extraction. Hope this helps...
tech to tech
I like the sound of this if you had the tools...
"Tap extraction is the process of electrically disintegrating a broken tap, drill, bolt, screw or pin. An alloy tube of various sizes is lowered drill-press style onto the broken component. An electrical current then disintegrates the broken component until it crumbles and can be chipped out, leaving the threads/hole undamaged."
also
"When you finish repairing a hole, make sure you use anti-seize on the new studs or bolts before you install them, so you (or the next tech) won't have to go through this the next time. On exhaust parts, use brass or stainless steel nuts and lock washers, so they don't corrode in place."
tech to tech
also
well im going to take it to my friends, dads shop... he looked at it and said honda didnot mean for this to be tampered with. i thought it was rusted but the bolts were actually welded... i later realized this after cuting 2 of them. but this thursday im going to take it over there. he said he can get them out... ill have a full product review for a skunk 2 catback for 7th gen civics soon!
crazx2lvr
13
Sep 16, 2005 12:50 PM
Matty Civics
Sep 6, 2005 08:21 PM
