No beep indication when I leave my lights on (2002 Honda Civic LX)
Old Sep 10, 2014 | 09:43 AM
DjArcadian's Avatar
Default No beep indication when I leave my lights on (2002 Honda Civic LX)
I believe that when I turn my car off but fail to turn off the headlights that there should be some type of beeping noise indication. However, my car doesn't do this. I checked the fuses and they all seem to be in fine. Is there anything else that would cause this problem? Every now and then I'll park and forget to turn my lights off so my battery dies.
Old Sep 10, 2014 | 04:46 PM
itburnswhenIP's Avatar
it could be the back up fuse 10a or a bad driver door switch which is located in the driver door jam. its held inplace with a phillips screw. you can pick this part up for about $5-$10 at your local dealership
the part # is 35400-S5A-013
here is a DIY Fixing Honda Civic door jamb switch and headlight buzzer reminder alarm - YouTube
Old Sep 14, 2014 | 06:54 AM
DjArcadian's Avatar
I actually discovered that there's a sensor switch on the door which can disconnect and cause this problem. Youtube at
helped. It was a fairly easy fix but difficult to fish out the sensor.
Old Sep 14, 2014 | 05:54 PM
discovered or read the post obove ???
DaCapitan
Jun 10, 2012 11:20 PM
icecolor
Sep 6, 2009 06:09 PM
mcaldera
Aug 28, 2007 07:52 PM
brianrtr
Apr 25, 2006 01:46 PM
civicboy01
Jan 8, 2006 09:22 AM
