1.6i, changed timingbelt, no spark or fuel now
Old Aug 16, 2007 | 12:16 PM
shuttle's Avatar
Default 1.6i, changed timingbelt, no spark or fuel now
Hi
I have gotten a major problem with my civic now, its a 1.6i, 1988. The car was running fine until i decided to change the timingbelt, i took it off and put the new one back one, and put the engine on the timingmarks, and everything seems fine. The strange thing is, now i dont get the car started, i have neither spark and i can not hear the fuelpump running when i turn the key.
I havent touched anything cept for doing the timingbelt, and disconnected the battery, what can have happened to make the fuelpump not running, and at the same time i get no sparks either?
anyone have any good advice on what might have happened here?
can there be a fuse, a relay or simply something that gotten unplugged?
Thanks in advance for all ur help
Old Aug 17, 2007 | 03:22 AM
Default RE: 1.6i, changed timingbelt, no spark or fuel now
Get in the car, put in the key, and turn it to the ON (not run) position. Does the CEL come on for a second, then click off?
If not, replace your main relay. those old hondas are infamous for eating main relays.
If it DOES come on then click off (and you can hear your fuel pump priming) you've got other issues.
Old Aug 17, 2007 | 06:41 AM
shuttle's Avatar
Hi
thanks a lot for ur answers.
The cel light was acting a bit strange at first, it kept flashing a few times, then it went off, but after i tried turning the key some more, the light dont flash, it comes on, but i cant hear the fuel pump running, and if i try to start the engine, the cel light comes back on a little, like its glowing if u know what i mean.
will the main relay cause it to not have spark also? or is it just the fuelpump?
wich one is the main relay, is it the grey/beige under the dash, or is it the smaller black one?
Thanks again for ur help
Old Aug 17, 2007 | 07:32 AM
Check the ground wires, especially the little ones on the back of the engine (thermostat housing). I don't think it's the main relay nor would it have anything to do with your timing belt change, it's just bad luck. Light coming on halfway like that suggests a power or ground problem.
Old Aug 17, 2007 | 12:12 PM
shuttle's Avatar
Hi
Wow, thanks a lot for ur help, ur answer couldnt be anymore perfect than this. Of course i had taken off the termostathousing, and not put it back on yet.
When i put the housing back on, the car started on first try.
You just saved me for hours and hours of endless trying and failing, it never occoured to me that it was a ground wire located there.
Thanks a whole lot again, you just saved my day (or weeks)
7kyle7
Aug 31, 2013 06:11 PM
Ocellaris
Nov 7, 2011 03:09 PM
JizzleCX
Apr 15, 2009 12:41 AM
djcompton
Aug 5, 2008 04:35 PM
BuzzOrHowl
Jan 9, 2007 08:44 PM
