1995 Honda Civic Start Problem
This distributor is from a B series engine so its slight different then yours but still set up the same. The red arrow points to the ignition coil.
The distributor has the cap, rotor, ignitor chip, and coil protector plate removed:
It turns at half the speed of the crank shaft, which is rather slow when you're just using the starter. If it turns at all, that means the timing belt is not stripped.
The spring on top of the coil should not be bent like that. Look at the cap where it meets it to see if it has been sparking to the side.
The tip of the rotor is normally burned like that. What you're looking for is cracks or burns in the plastic parts. The screw is totally stripped. You'll need to get that screw out to replace the rotor or the coil.
David_S
Oct 24, 2013 10:06 AM
eribertogracida
Oct 1, 2012 03:50 AM
PROLINE
May 24, 2008 06:23 AM
civicwontstart
Nov 1, 2007 07:31 AM
1995, 95, civic, die, distributor, honda, honde, issues, mechanical, problem, problems, start, starting, troublesshoot, youtube
