1998 civic no crank no power
Old Aug 17, 2020 | 05:59 PM
Carlosss77's Avatar
Default 1998 civic no crank no power
Hi all. New here. Recently purchased a 98 civic. Had a quick disconnect steering wheel the horn button was not hooked up, instead was hooked up to a switch which was installed under the steering whee. I tried to hook up the wires to the steering wheel hub but when doing so, I touched the hot wire from the horn to the ignition switch and immediately turned my car off (had it running for AC, it’s hot here &#128514. When I attempted to start the car, there’s no power whatsoever when turning the key. But the lights and emergency signals work. Did I short out the ignition wiring harness out?? Thanks in advanced
Old Aug 18, 2020 | 01:47 PM
drakon543's Avatar
did you check all the fuses yet?
D.Berry
May 26, 2009 10:36 PM
99bluetec
May 6, 2009 10:19 AM
98civicnewbie
Apr 21, 2008 11:02 AM
Mr Mobsta Man
Dec 23, 2006 05:36 PM
uk civhead
Oct 15, 2006 02:03 PM
