hooking up a horn
Old May 16, 2009 | 09:21 AM
D.Berry's Avatar
Default hooking up a horn
not really sure where to post this at...but im trying to hook a horn up to the steering wheel...i just recently got the honda...its a 94 ex...the previous owner had it running to a button under the dash but one wire was hook to the horn an the other wasnt going to anything...any help???...want to have it hooked back into the steering wheel
Old May 25, 2009 | 10:55 PM
D.Berry's Avatar
ttt...
Old May 26, 2009 | 04:17 AM
You'll want to trace the wires back from the button to see where the former owner spliced wires in. There is a bundle of wires that comes off the steering column. That's the most likely location where the wires were cut/spliced for that little mod.
One of those will be a ground and the other will be the power. What color are the wires?
Old May 26, 2009 | 06:01 AM
That model has a cable reel (aka "clock spring") to link the electrical stuff on the steering wheel to the rest of the car. It is an expensive part so should it fail there is a tendency to jury-rig a horn button instead.
Also if the clock spring is indeed broken, the air bag will not work either.
Old May 26, 2009 | 10:36 PM
D.Berry's Avatar
well there was a red wire going to the horn...an a white one that was jus hanging under the dash
Rhino40
Jan 18, 2009 11:56 AM
jhsplaya08
Oct 18, 2007 04:33 PM
Bostonhoodhop
May 12, 2007 11:20 AM
Phalcon
Mar 27, 2007 10:28 PM
Bostonhoodhop
Mar 10, 2007 06:26 PM
