2000 Honda Civic Radio - HELP!!!
Old Oct 8, 2008 | 06:28 PM
  #31
Can you press out some of the strategically located metal tabs in the cage to lock the radio in the proper position?
Old Oct 8, 2008 | 06:33 PM
  #32
iamsomewhere's Avatar
I figured the metal tabs were just for holding the deck sleeve into the aftermarket install kit. You can't really bend the ones on the sides because of the brackets you see me holding on to in the first picture. They pretty much sit flush to the sides of the deck and any holes that are on it don't match up with the new deck.
Also, on top and bottom I don't see any way to bend the tabs?
Old Oct 8, 2008 | 06:39 PM
  #33
Can you remove the cage from the center panel and then install the free cage over the radio? Then you should be able to access the upper and lower tabs to lock the radio to the cage/sleeve. Next, install the radio/sleeve unit back into the center panel.
Old Oct 8, 2008 | 06:52 PM
  #34
are these "upper and lower tabs" on the top and bottom of the sleeve (i'm assuming), or on the sides?
Old Oct 8, 2008 | 06:58 PM
  #35
xsteinbachx's Avatar
If you had this IN the car, it'd be held back by all the wires, and the backing of the dash. That could be a big reason for your problem. I've never heard of taking out the dash to install the deck, and then putting back in.. Sounds alittle odd, and how do you expect to attach the harness and wire everything if the deck is already in place.
Usually you have the dash installed, and with the deck hanging wire everything ,and then shove it (gently) back into the dash.
Old Oct 8, 2008 | 07:04 PM
  #36
The normal procedure for a radio installation in a 2000 Civic is to remove the entire center panel as shown in the pictures. I only know this because I also have a 2000 Civic.
Old Oct 8, 2008 | 07:07 PM
  #37
Use any tabs (top, bottom, and sides) in the free sleeve/cage that allow you to secure the radio in the desired position within the sleeve.
Old Oct 8, 2008 | 07:24 PM
  #38
if the deck is already in the sleeve I can't get to the tabs again to remount it to the aftermarket kit. It has to be done with the deck out of the sleeve.
Old Oct 8, 2008 | 07:30 PM
  #39
Okay. With the sleeve installed into the center panel (as shown in your picture), you may be able to access metal tabs above and below the inserted deck to secure it. Access to the tabs from the rear of the inserted deck. Bending the tabs may require the use of a long flat-head screw driver.
Old Oct 8, 2008 | 07:59 PM
  #40
Sigracer10's Avatar
your problem is here on the tab circled in the pic below
these tabs on each side of the radio are what hold the radio in place inside the cage. Push these tabs in toward the inside of the cage and put the radio back in. That should give the tabs enough pressure against the radio to click and stay in place.
