90 Civic DX Cranks But won't start
Old Jun 20, 2010 | 12:01 AM
Li'l Red's Avatar
Default 90 Civic DX Cranks But won't start
I had a broken cooling system hose and when I replaced it I apparently knocked a plug wire off the distributor. When I tried to start it it started and ran rough and died. ( I think I then tried to restert immediately and it wouldn't catch at all) I found the loose plug wire and resetaed it on the distributor. It won't stat and doesn't give any hints of starting either. I pulled the cap and replaced the rotor I never got to a week ago when I did a tune up. No change. I drive this car from time to time for work and I need it running by early Monday. My guess is that trying to start it with the wire disconnected caused the iginiter and or coil to snap.
I have the Chilton manual and it lays out the testing procedure for the coil and igniter, but if someone can narrow this down or help with good advice-thanks
Old Jun 21, 2010 | 08:02 AM
Take the cap off and try to draw sparks to a grounded test wire you hold near the coil output. If you only get little yellow sparks, coil is blown.
Old Jun 21, 2010 | 09:36 AM
Running or cranking the engine with a plug wire disconnected may blow the coil.
Old Jun 24, 2010 | 10:57 PM
Li'l Red's Avatar
Thumbs up
Well thanks a lot to you and HCF.com. You said a yellow spark means bad coil and that was just what it was.
Mecca8383
Mar 31, 2014 05:15 AM
armyofdux
Jul 21, 2011 04:37 PM
justafan
Jan 30, 2011 03:31 PM
ncombs
Apr 29, 2010 07:09 PM
hondamom
Jan 13, 2008 05:47 PM
