98 Honda civic ex , front suspension noise. Popping sounds coming from the front!
I have a 98 honda civic coupe , I have replaced everything in the front suspension from inner and outer tie rods , upper control arm , and lower ball joints, sway bar end links and struts. I didnt replace the cv axles nor the lower control arm ot sway bar bushings , which either dont look bad too me. It is hard to tell for the cv axles cause boots are not teared but I know there could still be a problem going on inside the boots!
Sorry for a very late reply, did not think anybody was going to reply to me. Noise happens when I get the steering wheel a little turn to the left and right while and park at the position it sounds like a little knock, pop, clunk something like that. But when i’m turning out of a parking space, like wheel turn left or right, it like pop. Pop .pop till I straighten out. Also when I take off, it pops. I replaced almost every suspension part like I said except the rack and pinion and lower control arms. Noise does not happen when the car is lifted, when I turn the steering wheel when its raised no noise. Tried shaking components, make no noises. I did get an alignment, didnt last for long till my steering wants to turn left and I got that popping noise
Struts are close to new, got a whole suspension kit from 1aauto, only affordable thing at the time. Also replaced cv axle and the noise is still there. I lift the car up, it makes no noise when I turn the steering wheel. On the ground, a different story, just a little wiggle and I hear a clunk, but when actually driving and turning the wheel, its like pop pop pop. This popping noise seems to have affected my alignment also as my steering wheel always pulls left!
Is it power steering? Could it be air bubbles in the fluid? You tried bleeding it?
It wouldn't be affected if the car is off the ground, but when it has to work against something the hydraulic pressure is greater.
Have you checked the fluid level and looked for leaks?
hagman81
Nov 12, 2008 04:06 AM
bleedhondos
May 2, 2005 12:00 PM
