ac only works randomly help
Old Jul 27, 2010 | 12:11 PM
Do not jump the pressure switch.
From reading the other forum it appears that you're not very experienced with electrical work. It may be better off to find (i.e. pay) someone local to look at your car in person.
Old Jul 28, 2010 | 02:11 PM
swizz977's Avatar
if its my hvac would this fix the problem? http://www.hmotorsonline.com/shop/sc...age&item=20003
Old Aug 21, 2010 | 02:04 PM
swizz977's Avatar
ok so today my ac was not working and i started hitting the climate control and it started working.. and then it stopped and i hit it again and it went on again.. so i guess its my hvac switch then right?? how can i just test the hvac right now to see if thats the problem?
Old Aug 21, 2010 | 04:29 PM
It seems that through percussive maintenance, you have already tested it.
Replace the switch.
Old Aug 22, 2010 | 12:10 PM
swizz977's Avatar
my car is shaking on and off when my ac is on sometimes not constant also
Old Aug 22, 2010 | 12:16 PM
That's a different problem. If the condenser fan is running, it is usually because the IACV is dirty and the engine can't idle strong enough to handle the load of the compressor.
It is looking more and more like your control panel is bad that's why the A/C doesn't run all the time.
Old Aug 26, 2010 | 03:30 PM
fishindude911's Avatar
I changed the buttons and havent had any problems since and its been over 2 months
Clean_Civic_98
Sep 23, 2010 06:15 PM
99lx
Aug 21, 2010 09:57 AM
gishar
Jun 28, 2010 12:10 PM
joelmatt89
Jan 7, 2009 08:07 AM
runawaylegalsec
Apr 19, 2006 09:19 AM
