allignment???
how much does it cost to get an allignment? or could i do it myself...my car has lowering springs and my car shakes at like 60mph and my tires aretilted in and is wearing my tread on inner tire
You need to install a camber kit to be able to adjust that tilt out, it is not adjustable on the stock suspension.
Improper toe-in will also cause the tires to wear excessively on the inside edge.
Shaking at high speed is usually a wheel out of balance, not alignment.
plus they wont align it when it has camber problems, well they didnt want to on my s10 i used to have. so i just had my freind align it by eye. turned out real good although it still pulled just a little but i was happy.
If your car is shaking you might need to get your tires balanced too. It doesn't cost much so i'd just go do it if I were you. Anyway, I paid $60 for my alignment. They probably won't be able to get your camber all the way to stock, but they should be able to get everything else. A little negative camber will be fine.
silverbullet01
Jul 31, 2008 12:28 PM
ISSABELLE19
May 1, 2007 02:24 PM
phishy
13
Dec 16, 2006 01:23 AM
