allignment?
yes did u put on the lowering springs yourself because whenever you lower your car or mess with your suspension you need to lower it everytime you are done doing that. Your toe is probably off really bad thats how my car was but i got alighment and i was off like 40 degrees so i would recommend gettin an alighment before you go through a set of tires
did you get an alignment after you installed the springs?
any time you alter the suspension you need an alignment. your toe is probably way out of whack. also, get your tires balanced, it'll help with the shaking too.
silverbullet01
Jul 31, 2008 12:28 PM
ISSABELLE19
May 1, 2007 02:24 PM
phishy
13
Dec 16, 2006 01:23 AM
