Do I need to GET AN ALLIGNMENT AGAIN??
Old May 1, 2007 | 03:02 AM
ISSABELLE19's Avatar
Default Do I need to GET AN ALLIGNMENT AGAIN??
Hello! I have an allignment 4 weeks ago at pepboys because i lowered my ride. ( Installed a tokico illumina shocks and tein spring) . Then 3 days ago i decided to replace my old kumho ecsta tires with 4 new pirelli pzero nero ms tires. My question is, do i need to do an allignment again? the pepguy told me i dont need to because nothin have change and it does not affect the alignment by changin the tires --- but i need to make sure--- so im askin you guys for your opinion . Thanks!!
[IMG]local://upfiles/18842/2810CA8731FB4A44A48034ADF5A7B338.jpg[/IMG]
Old May 1, 2007 | 03:23 AM
danomatic93's Avatar
June 2010 ROTM
Default RE: Do I need to GET AN ALLIGNMENT AGAIN??
nope, no need to.
If you had coilovers and were adjusting the height a ton, maybe, mayyybe you'd need an alignment.
The best way to tell if you need an alignment is drive on a flat, straight road. Let go of the steering wheel. If the car pulls to the left or right noticeably, you'll need an alignment.
Don't forget to grab the steering wheel when you are done checking.
Old May 1, 2007 | 02:24 PM
conceptualpolymer's Avatar
...or if you changed the diameter of each tire, significantly. Otherwise, dano is correct - no alignment!
BTW, an out-of-alignment condition may still allow the car to track straight. This would happen if the caster/camber is out of spec. and yet the rotational position, left-to-right was correct. As a general rule-of-thumb, look at your tires whenever you add air. If you see uneven weat across the treads, an alignment may be necessary.Most vehicles don't need alignments for many years.
funnymonkey24
Sep 22, 2010 07:43 PM
silverbullet01
Aug 9, 2008 03:49 PM
silverbullet01
Jul 31, 2008 12:28 PM
silverbullet01
Jul 5, 2008 05:39 PM
phishy
13
Dec 16, 2006 01:23 AM
