Blew Gasket... again
Old Sep 22, 2007 | 11:56 AM
Live_4it's Avatar
Default Blew Gasket... again
Well, I believe I blew the midway gasket in my 4-2-1 header.... again. I think it happened when it was a rainy day and my car had 4 people in it, two of the people over 250 lb.s (one of them including me) and I was also goosing it around a bit.
The new gasket I plan on putting inis rounded off on one side and the other side is flat. I believe the rounded off side should be faceing where the exhaust is coming from right?
I plan on just unscrewing the two piece header, and just dropping the exhaust pipes down. Then replaceing and tightening. Run it hard a few times then retightening. Anything I'm missing or should also do?
Thanks.
Old Sep 22, 2007 | 04:35 PM
skibum853's Avatar
Default RE: Blew Gasket... again
when you have it apart take a stright edge and make sure the flanges arnt warped at all. if they are, even if you torque the bolts to spec, a little bit of hot gas will seep by and eventually do it again.
Old Sep 22, 2007 | 08:30 PM
Live_4it's Avatar
Heres the old gasket I took out, hopefully the new one will last longer. It broke into two pieces.
[IMG]local://upfiles/17640/C4C55F9A16A84F4E8C4BCFF76C607F8B.jpg[/IMG]
Old Sep 23, 2007 | 09:15 AM
DreamTeam87's Avatar
where are you gettin new gasket cause i need a new one to for mine i have a small exhaust leak in mine and couldnt find another gasket for it....it look exactly like the gasket you have for my 2 piece header
Old Sep 25, 2007 | 06:51 PM
Live_4it's Avatar
sorry haven't been on in a few days....
DreamTeam87: I bought mine off the meganracing website, it costs $15 for two replacement gaskets.
It's been working well after I replaced the gasket [sm=smiley20.gif], meganracing tech support said to torque down the middle nut first than the other two, to 15 ft lbs. Then after running it for a little bit torque to25 ft. lbs.
wil
Jan 18, 2013 04:27 AM
NIKE H34D
Jun 28, 2009 05:36 PM
redblur07
EK Swaps
May 1, 2008 02:28 PM
Naudlee
13
Jun 27, 2006 10:02 PM
rickyellow90
Jul 6, 2005 07:18 AM
