civic transmissions
Old Dec 4, 2006 | 07:32 PM
WhtRice's Avatar
Member
Default civic transmissions
howdy long time not talk/post. Anyways Just an update, i went through the DIY short throw shifter install and applied it to my 00, i also replaced the bushings with polyurethane ones and it turned out brilliantly.
I offer a quick question though, my civic has 91k on it and i purchased it at 88, as you can tell i just put around town and to work with it. Ever since i bought it the tranny has problems going into reverse, like if i put it in and release the clutch it wont engage Reverse sometimes, so i put it in 5th then reverse FIRMLY and it goes. I think i have to replace the tranny its the stock one that comes with the D16y7 motor..can i bolt up a stronger tranny to this motor? like a GSR tranny or even an RSX-S 6 speed?
VERY INTERESTED
thanksb
Old Dec 4, 2006 | 08:23 PM
riceburner700's Avatar
Default RE: civic transmissions
you can only swap in another d-series tranny. try changin the tranny fluid with some honda mtf or some gm syncromesh it works wonders
Old Dec 4, 2006 | 08:37 PM
WhtRice's Avatar
Member
ahh *****...well i'll go find an Ex tranny i heard theyre built a little more agressively anyway, i'll try the fluid swap first though of course.
Old Dec 4, 2006 | 08:40 PM
Misha's Avatar
I think all or almost all manual trannys do this time to time, this is by design. The easy method to put it into reverse if it does not want to is to release the clutch and depress it again. This turns gears to a different position.
curlybandit
Aug 4, 2006 11:06 AM
leco516
Mar 13, 2006 01:48 PM
thakid
Feb 10, 2006 02:46 PM
91crx_87
Sep 19, 2005 10:03 PM
DV92Camaro
Jun 23, 2005 04:42 PM
