code P1753 how to fix it?
Old Mar 14, 2011 | 03:17 PM
cajundude's Avatar
Default code P1753 how to fix it?
I have a 2001 civic with the following problem, "D" flashes in instrument panel and my scanner pulls a P1753 code.I know that it has something to do with the torque convertor circuit. Is this something that is internal? or is it an external solenoid ? Any help you can provide would be great as I am trying to get the car back on the road.
Old Dec 11, 2011 | 01:48 PM
Aaron A Archer's Avatar
I've got the same problem, let me know if you find a solution
Old Dec 12, 2011 | 02:33 PM
I fixed mine. I took the Shift Solenoid from below the distributor and sprayed it with carb cleaner, I didn't have an air compressor but I blew it out and kept cleaning. I put it back on and the reset the ECU (I have done that many times) AND NO MORE FLASHING D4!!!!! If anyone needs a solution or fix for a flashing D4, they need to try this one first!!
Old Dec 12, 2011 | 04:09 PM
cajundude's Avatar
Default trany fix
i forgot to plug in a wire below the distributor . after I plugged it in ,all problems went away. I do not remember exactly what plug it was . sorry
Old Dec 2, 2018 | 03:49 PM
kaila.777's Avatar
So ur saying that if i clean my shift solenoid very well, it will remove my d4 blinking phase and fix my shifting problems?
99lx
Jul 18, 2013 01:29 PM
comeasyouare1925
Feb 17, 2012 02:58 PM
rudsta
May 3, 2010 05:20 PM
00hondacivicsi
Jan 15, 2010 09:34 PM
greycoupe
Jan 17, 2008 01:36 PM
