Cooling Fan Wont cut on
Old Jun 14, 2007 | 02:07 PM
ktownjeep's Avatar
Default Cooling Fan Wont cut on
My cooling fan wont turn on my 93 civic.
I connected it directly to the battery and it worked.
Old Jun 14, 2007 | 02:55 PM
Default RE: Cooling Fan Wont cut on
Locate the coolant temperature switch, which is on the thermostat housing (where the lower radiator hose connects to the engine). Unplg the switch and jumper the two pins in the connector. Turn the key on and the fan should run. If it doesn't, could be the fuse or relay. If it does, replace the switch.
Old Jun 14, 2007 | 05:25 PM
ktownjeep's Avatar
Thats the problem. Thanks alot for the help.
Tealingston
Dec 12, 2008 10:59 AM
lillyrat
May 22, 2007 09:31 PM
mitchamus
Jan 2, 2007 02:28 PM
DashRendar77us
May 25, 2006 07:29 PM
jad1217
May 20, 2006 05:16 PM
