Dim Headlights
Old Jul 3, 2010 | 09:04 AM
the_sponge's Avatar
Default Dim Headlights
I have a 2001 Honda Civic. Recently when I am driving my headlights are really dim but the right one will get bright after a certain acceleration then go back dim. Then they will both turn bright but for a VERY short amount of time. I had the battery and alternator checked and they are both fine. What else could it be?
Old Jul 3, 2010 | 10:59 AM
SilverSedan's Avatar
I would suspect wiring issues. First place I would check is the connection between the headlight bulb and the harness. Bad power or bad ground, but other then that I couldn't tell you where to start.
Perhaps RonJ or MK will post... both have a TON of knowledge!
Old Jul 3, 2010 | 03:48 PM
+1 on the grounds. That's almost textbook bad grounds with headlights, actually.
I'm not sure where the ground wire for the headlight part of the wiring harness is though.
Ohio3Der
Mar 6, 2012 07:25 AM
naples10
Nov 29, 2010 03:07 PM
Ohio3Der
Nov 17, 2010 09:33 AM
san
Apr 6, 2006 08:17 PM
spevie
Oct 6, 2004 03:50 AM
