driver side window won't work (help)
Old Nov 11, 2007 | 07:18 PM
import4life's Avatar
Default RE: driver side window won't work (help)
i just checked and i dont have power to fuse #5 what would be the most likely cause of that if the fuse is good
Old Nov 11, 2007 | 07:23 PM
Just curious, can you describe the test that tells you that there is no power at fuse #5?
Old Nov 11, 2007 | 07:33 PM
icould be wrong on this but here it goes with the key on the on position and i put my test light on one side of the fuse and get nothing and put it on the other side and nothing either.
i thought that fuse should have power going to it with the key on the on position
Old Nov 11, 2007 | 07:46 PM
If I understand your test, it would not complete the circuit, so the light would not go ON even if there is power. Touch one probe to one side of the fuse and the other probe to part of the grounded metal framework under the dash. Hold only long enough to see if the light go ON. if it does, you have power at the fuse. But yes, to do the test the ignition must be ON to supply power to the circuit.
Old Nov 11, 2007 | 07:50 PM
would you happen to know where the power window relay is located?
Old Nov 11, 2007 | 07:57 PM
See picture for relay location.
[IMG]local://upfiles/25538/F3CC3368625147A4B65D446FA4987383.jpg[/IMG]
Old Nov 11, 2007 | 08:08 PM
you were right i completed the circuit and it does light up my test light. so ill do further testing from which you provided earlier. thanks
would you know how to test the power window relay
Old Nov 11, 2007 | 08:18 PM
I don't think problem is the window relay because it controls ALL windows (your passenger window works).
Here's the relay test:
[IMG]local://upfiles/25538/DCD8A6036FDD4447B2D9F79127933914.jpg[/IMG]
Old Nov 11, 2007 | 08:34 PM
ok thanks for your help
Old Nov 11, 2007 | 08:40 PM
Good luck with the troubleshooting and repairs.
