e-brake light problem
Old Oct 17, 2010 | 09:10 AM
chrisrich's Avatar
Default e-brake light problem
HI, im new here, and have a question.
i drive a stock 99 civic cx. when i accelerate in 1st and 2nd, once i reach 3000rpm, my e-brake light (!)
will light up, and stay on until i shift or let off the gas. i have held the brake lever down hard while accelerating, but the problems remain.
any thoughts on this? this has me and my buddies stumped.
thanks!
Old Oct 17, 2010 | 09:13 AM
You might wanna check on the little switch under the ebrake that controls that light. To get to it, you have to pull the arm rest/console off. Check and see if the switch is damaged or has moved somehow.
Old Oct 17, 2010 | 09:37 AM
It will also light up if the brake fluid level is low. Check that you have enough. You could also disconnect the switch on the reservoir as a test to make sure that's not triggering it.
adb
Jul 15, 2012 09:22 AM
juniorbiscuit
Oct 15, 2010 12:24 PM
gunaa
Oct 22, 2009 11:36 AM
sir_nasty
Mar 27, 2006 03:09 PM
92_Civic_HB_Si
Dec 11, 2005 11:51 AM
