EJ8 Help Needed
Old Mar 31, 2007 | 08:02 AM
Civic98KH's Avatar
Default EJ8 Help Needed
every now and then, when i go to start my car it takes a little while for it to start. brand new battery and brand new fuel filter on it.. any ideas on what it could be?... and any solutions as far as like a cleaning of something job... and its not frequent, just every now and then .. and the crank is turning, just doesnt fire right away .. maybe spark plug wires or spark plugs?... please let me know what you think, thanks a lot
Old Apr 2, 2007 | 07:43 AM
Default RE: EJ8 Help Needed
how old are your plugs and wires? Maybe its time for a new cap&rotor on the dizzy. Could be a number things.
Old Apr 2, 2007 | 11:32 AM
the_turtle's Avatar
im having this same problem, if its cold....it will crank maybey 3 seconds before it fires....if its cold like as in weather wise below 40 it might crank 5 seconds....but i have noticed that if you crank it like twice, then hit the key agian, it will usually fire right up.
I have new plugs, 3k miles on them, wires and dizzy are stock. i was kindof leaning to weak injector, or fuel pump, but now that i think of it, i belive the problem to be in the dizzy.....Its not like i feel that im going to go out and my car wont start, its just anoying to have to crank it so much.
Some day (when i have enough saved for the dragon and or prom) im going to get a whole new ignition set up. (msd sport compact ignition, msd dizzy and blaster coil as well as new wires) so that should solve the problem.
Old Apr 2, 2007 | 03:57 PM
cpl rampage's Avatar
i have mine does that every so often, expecially if i either let it sit for a while(day) or if im low on gas, i think it has to do with the fuel pump priming
Old Apr 3, 2007 | 10:58 AM
the_turtle's Avatar
could be, but i think the dizzy also has somthing to do with it....but i cant complain with 155k on the stock one.
paintballer1184
Apr 13, 2014 06:02 AM
SovXietday
Jul 19, 2007 10:50 AM
Civic98KH
May 7, 2007 06:32 AM
that guy
Apr 14, 2007 12:45 PM
JDMracer00
Feb 18, 2006 12:17 AM
