EM2 Stalling issue
Old May 30, 2020 | 03:14 PM
Dropped94civic's Avatar
Default EM2 Stalling issue
Hey guys,
I have a EM2 that ive been working on. The issue is the car will sometimes die when i shift into neutral. Example, im approaching a stop light so ill shift into neutral and coast. While coasting, the dash lights flicker or the car will just die. I restart with no problem but i cant figure it out. I've replaced the air filter, cleaned the throttle body and Electronic air control valve on the throttle body, and replaced the PCV valve. No rough idle or any other issues. Any ideas or things i should check?
Old Jun 9, 2020 | 05:49 AM
StifflersMom's Avatar
Cat Fuсker
Sounds like a charging circuit/battery issue. I think that because of dash lights flickering. Also, I'd check grounds from engine to body and the negative from battery to body for corrosion.
dlcraig1
Mar 29, 2014 10:43 PM
harleystcool
13
Nov 11, 2009 09:33 PM
bradf_nc
Apr 13, 2009 06:24 AM
Jippo99
Aug 28, 2007 03:54 PM
VinceDee
Jun 21, 2007 04:09 AM
