Engine Dies out
I have a 99 Civic Si with 122,XXX miles on it. When im out driving no certain time or temperature the motor seems to lose power really slow down and then kick back up to normal. its no certain RPM's or gear...ive had it happen in all gears. I had a similar problem b4 but that went away...now the car really loses power and loses it for a good amount of time..what could it be? THanks
yeah the CEL is on it says its for the front 02 Sensor but this sensor has been outta wack for awhile and this problem just started up. Would it be one of those problems...alternator, clogged throttle body..etc..even though its not consistent?
Im in the process of changing my front 02 Sensor, the guy who had this car b4 me put a universal 02 sensor on it and cut the plug that you plug the 02 Sensor into, so right now im trying to get that plug and splice it back into the wiring, so a new front 02 sensor is on the way.
1) Pull the CEL codes, and note them. Clear the ECU, and when the CEL turns ON, again retrieve the codes. Troubleshoot only repeated codes.
2) Fix the O2 sensor, which is required for the ECU to determine the optimal air:fuel ratio. This is critical for engine performance and possibly could be the cause of your problem.
drewrussell2011
May 17, 2014 07:57 PM
NIKE H34D
14
Jul 20, 2010 07:49 AM
Sidlexic
19
Feb 12, 2009 07:20 AM
vladio
Feb 8, 2008 07:06 PM
ErikElvis
Mar 20, 2007 02:52 PM
