Engine problems
Old May 4, 2007 | 05:58 PM
mrblades's Avatar
Default Engine problems
Hi, I have a 1998 civic dx that has been experiencing engine problems that I cannot track down. The symptoms are that the engine will be runnung just fine most of the time but sometimes the engine "hesitates."The car dies without sputteringand the little enginesilhouettelight comes on and then after a short period of time (sometimes less than a second sometimes about 2 seconds) the car starts back up. I have found that I can get it to restart faster by pushing in the clutch and quicklycycing the key off and than restarting the engine.
This has been going on for sever months and then today it happened and the car didn't restart and the little enginesilhouettelightstayed on. I puled off to the side and cycled the key acouple times and that didn't do it and the light still stayed on. I popped the hood and checked to make sure the spark plug wires were tight and they were. After about 2 minutes, I tried to restart and it started right back up and ran like nothing had happened.
I would appreciate any tips, advice, or knowledgethat might be useful. Thank you in advance.
Old May 4, 2007 | 06:31 PM
hatch46580's Avatar
Default RE: Engine problems
sounds like your main relay is going bad. it located right above were your hood release is located its a black box. or you fule pump might be going out also
Old May 5, 2007 | 03:39 AM
elusive_da's Avatar
i think hatch got this 1.... u need morehelp let us no.... good luck
Old May 5, 2007 | 01:37 PM
mrblades's Avatar
Thanks! I will try that and see if it works.
Tonymore
Jun 10, 2006 10:31 PM
bo55_555
Feb 8, 2006 04:00 PM
psychojetpilot
Jan 23, 2006 11:47 AM
pirata
12
Dec 21, 2005 04:22 PM
kewlphil
Jul 1, 2005 11:05 AM
