fuel trouble?
Old Apr 22, 2010 | 08:20 AM
89tote's Avatar
Default fuel trouble?
so i have a 89 hatch with the d15 dpfi and every now and then i will go to start it and it will just crank and i can listen and not hear the fuel pump so i turn the key off wait 2 or 3 minutes and it works any ideas
Old Apr 22, 2010 | 08:36 AM
Try resoldering the main relay.
http://techauto.awardspace.com/mainrelay.html
Old Apr 22, 2010 | 09:09 AM
89tote's Avatar
would it be better for me to just get o new one from the yard by resoddering the main do you mean solder the relay or the wires going to it
Old Apr 22, 2010 | 09:46 AM
Did you read the link that Ron posted? It's quite good. In a nutshell, take the relay out of the car, pry the plastic case open, and resolder the circuit board inside. If you buy a used relay, resolder it too because they factory solder job will pretty much always go bad after enough bumps in the road.
I would not mess with the desoldering stuff the link is talking about. Just heat up each joint and apply more new solder. If a joint still looks suspect after doing that, dry off the tip of your soldering iron (use a wet rag or just flick the solder off) and use it to remove most of the solder from the relay joint. Then dry off that old solder and use new. If you've never soldered electronic stuff before, it would be better to find someone who has, or buy a NEW main relay.
Old Apr 22, 2010 | 12:34 PM
89tote's Avatar
new solder worked for it now anyone have any tips on converting it from dpfi to mpfi
CatsnotCars
Jan 28, 2015 12:24 PM
tombakers
Nov 15, 2007 04:09 PM
Da Chump
Feb 23, 2007 06:12 PM
TheBlackCivic
Jul 16, 2006 11:45 AM
nightrider46
Aug 23, 2005 03:42 PM
