Hard time shifting
Old Jan 9, 2007 | 09:21 PM
classiccarsrule85's Avatar
Default Hard time shifting
Ok so I was pretty sure there was a problem when i drove my 88 CRX hf home with shifting it since it took grunt power to put it into gear.....Tho I am not sure what the problem is , for its the same when the car is running and when its not, I depress the clutch pedal , the stick moves nice in the neutral position but when you try to put it into a gear it requires some muscle....when it drives the gears dont grind or anything like that either.....so yea I am unsure what it is....the Linkage needing to be really lubed??, or something worse really hoping its not the trans itself but yea anyone got anything???
Old Jan 9, 2007 | 09:26 PM
ic892003's Avatar
Default RE: Hard time shifting
yea i have the same problem in my 92 civic, its not using a lot of muscle to put it in gear, but it does require a "push" i dont think its a serious tranny problem or something to really worry about, its beenlike this for the past4 months like this, im not sure what it is, but anyway good luck 2 u maybe u can find out for the borth of us
Old Jan 10, 2007 | 10:23 AM
Red Hot Rider's Avatar
Checked your shifter bushings?
z_dizzlemang
Apr 25, 2008 07:52 AM
Drunkgoose
Apr 27, 2007 12:41 PM
goof41
Sep 10, 2006 12:50 AM
jmonkie
Oct 2, 2005 08:55 AM
troutman
Aug 27, 2005 12:45 PM
