idel jump up and down
Old Jan 12, 2009 | 02:04 PM
  #21
Dex_1995's Avatar
Ron...Thanks for all this help.....I am sorry I said that wrong....The port has a awsome suction while cold and come to a stop when warm...
Old Jan 12, 2009 | 02:12 PM
  #22
Okay, test whether the disconnected EACV has 8-15 Ohms across the two pins.
Old Jan 12, 2009 | 02:16 PM
  #23
Dex_1995's Avatar
OK Rod I will check that and get back with you with the details....Thanks
Old Jan 17, 2009 | 07:51 AM
  #24
Dex_1995's Avatar
Ok RonJ.....Checked the Ohms on the AICV....It seems mine after many checks is only reading 0.01. Since I cleaned the FITV the fast idle problem at cold start (2,900 rpm) is resoleved...Its now about 1000 or 1,100 rpm at cold morning start. After engine warms up the idle still wants to jump up and down..Its going from around 1000 to 1,300 rpms(much better than before i cleaned the FITV)
Old Jan 17, 2009 | 10:25 AM
  #25
Your Ohm readings between the two pins of the IACV suggest that it needs to be replaced. You didn't make those readings from the IACV wire harness connector, right?
Old Jan 17, 2009 | 05:10 PM
  #26
Dex_1995's Avatar
RonJ....that reading came right from the AICV not from the wire that connects to it..
Old Jan 17, 2009 | 05:14 PM
  #27
Good. Just checking.
fongcom
Feb 9, 2011 03:02 AM
kylea24
Nov 6, 2008 02:03 PM
peanutbiscuit
Feb 7, 2008 08:05 PM
SirTealingstonThe2ND
Nov 4, 2007 06:38 PM
Jul 5, 2007 09:48 AM
