jdm foglights.
Old Jul 5, 2010 | 06:23 AM
fo23rat's Avatar
well i bought the car last monday and when i got it i was like awesome full tank of gas. NOT! found out the gas gauge doesnt work abd it shows full all the time. what fuse do i check i printed a layout out cause the cover is missin but they seem fine maybe i ran over one and didnt check it but any suggestions.
Old Jul 5, 2010 | 06:47 AM
Take the bottom cushion of the back seat out and unplug the wires to the gas tank. Turn the key on and see if the gauge goes to empty. If it does, the sender in the tank is bad.
The speedometer, temperature gauge, etc. all work off the same fuse as the gas gauge-- so if those work it's not going to be a fuse.
Old Jul 5, 2010 | 08:19 AM
^This
There is one bolt just off center to the right of the bottom of the cushion. You can fold the back seat down to see this bolt. Its easier to remove with a 10mm? socket and an extender for your ratchet. Once the bolt is out, the seat cushion folds up like it's on a hinge, then you have to pull upwards to remove the whole thing. (If the seat is dirty, this is a good time to use a carpet shampooer or something to clean it.) The rest will be very easy to see. There is an obvious metal cover to the fuel pump and sender unit. You'll see the wires and the screws.
Old Jul 5, 2010 | 09:39 AM
fo23rat's Avatar
Ok I found one wire that comes undone I unplugged it and turned it on and the gauge didn't move. What now&
Old Jul 6, 2010 | 09:11 AM
fo23rat's Avatar
bump. need help guys!
Old Jul 6, 2010 | 09:51 AM
Two possibilities: Bad gauge or bad sender unit.
Last test: Get a spare gauge cluster, plug it in, and see if it reads differently. If so, swap the gauges between clusters.
Option 2: Replace the sender unit in the tank. Under that cover, you have to remove some screws (I don't have the diagram handy). One of those is the fuel pump, the other is the sender unit. Its more dangerous because the tank is open and you have gas fumes that could ignite so ventilate well.
Old Jul 6, 2010 | 10:09 AM
fo23rat's Avatar
well i did that thing where you unplug the wire and turn the car on and the gauge didnt move so its not my sender.
Old Jul 6, 2010 | 11:02 AM
Then it's either the cluster or the very rare possibility of having a short to ground in the wire from the cluster to the tank.
txedomask433
Dec 6, 2006 02:58 PM
ahhsimon
Feb 26, 2006 10:13 PM
ahhsimon
Feb 25, 2006 07:40 PM
wookmaster
Apr 6, 2005 06:32 PM
eXo04Coupe
Jun 4, 2004 01:16 AM
