loose tire! need help!
Old Jun 10, 2008 | 03:23 AM
Crus1's Avatar
Default loose tire! need help!
Hey Guys... need your help! I started hearing a knocking in my left front end and I jacked up my car and check my ball joints pushing up and pulling out and its tight with no movement. I then did the left and right test and i had some movement. I don't think its my ball joints because I do not see movement there however I do see alot of movement on the piece that is attached to my tire rod. When i pull on it I see it moving the steering wheel etc.I see it moving in and out of the boot closest to the car. What is this part b.c I cannot figure it out in the book. Also, is it easy to replace. Ifso cansomeone enlighten me! Iwill any info you can give me!
Thanks
Chris
kjsayers
Jun 10, 2010 10:06 AM
civicguy2488
May 23, 2010 07:44 PM
rs634158
Dec 27, 2009 02:57 PM
ejb11
Aug 9, 2006 03:35 PM
all2common
Jul 19, 2005 07:40 PM
