mini me need help
Old Mar 18, 2010 | 06:31 PM
chinobk's Avatar
Talking mini me need help
i just did a swap on my 93 cx hatchbak from a d15 i put a d16 vtek head after driving for 2 weeks im getting conpression inside my colant water bottle someone told me it was the termostat so i changed it but getting wite smoke out tailpipe can someone help
Old Mar 18, 2010 | 06:38 PM
Scott53092's Avatar
conpression in colant? Do you have oil in the coolant overflow? White smoke usually means you are burning coolant which leads me to believe your head gasket is bad, and if you do have oil in your overflow you have a blown head gasket for sure.
Old Mar 18, 2010 | 07:01 PM
did you have the head milled to make sure you had a sure flat surface
?? also pull the valve cover off and double check the toque on the head bolts.
what does the oil cap look like?
khanselman
Aug 25, 2006 12:40 PM
marcos
ED-EF Swaps
Jun 12, 2006 11:13 AM
civicblend97
Apr 27, 2006 03:38 PM
jusplayn85
Mar 7, 2006 08:20 PM
GSXF
Feb 23, 2005 09:45 PM
