More Fuel Pump Problems
Old Jul 9, 2010 | 03:12 PM
  #51
apoplectic1's Avatar
1. Yes, still only 0.011V
2. Yes
3. So just wrap the wire around the battery terminal, and around the prongs on the inside of the main relay?
Old Jul 9, 2010 | 04:53 PM
  #52
Did you also scrape away some wire insulation to test for voltage near the main relay plug?
That might work. A wire with alligator clips at each end might be easier.
Old Jul 10, 2010 | 07:27 AM
  #53
Double post, sorry
Old Jul 10, 2010 | 07:43 AM
  #54
1. I just did, I measured 0.013V.
2. On step 2 of the Main Relay testing diagram I measured 0.0Ω, on step 3 I measured 0.2Ω, on step 4 there was 0.3Ω. Is this close enough to zero, or is it bad?
Old Jul 10, 2010 | 08:18 AM
  #55
(2) shows that the main relay is fine. (1) tells you that the ECU plug is an unlikely source of the problem and that the main relay plug is now the prime suspect. Reasoning: Voltage reaches the main relay plug from fuse 24 but does not make it past this point, despite the fact the main relay itself is fine. I assume that the Blk/Yel- and/or Blk-wire main relay plug terminal may not be making good contact with the corresponding main relay terminal or one of these two wires is bad inside or near the main relay plug.
Old Jul 10, 2010 | 08:45 AM
  #56
So I should try to get my hands on a new plug?
Old Jul 10, 2010 | 09:42 AM
  #57
My bet is on the main relay plug based on its bad condition. However, here is the problem with that idea. Voltage reaches the relay plug on the Blk/Yel wire from fuse 24 just fine and the Blk wire has good end-to-end continuity yet never gets voltage from the main relay, despite also testing fine. In other words, all individual components test fine, which suggests but does not prove that the lack of voltage to the Blk wire is poor contact between the relay and relay plug. I'd be more confident if the individual tests pinpointed the specific problem, though by process of elimination the problem seems to point to the main relay plug.
If you are comfortable with this reasoning, then cut out a main relay plug (plus ~6-inches of each wire) from a junk yard 5th Gen Civic and properly solder it into your wire harness.
Old Sep 21, 2010 | 10:56 AM
  #58
OK, sorry it took so long--been a really ****ty and hectic last few months--but I got a plug. I'll install it in a few hours and post the results.
Old Sep 22, 2010 | 04:57 AM
  #59
Plug didn't fix anything. Still having the same problem.
Old Dec 21, 2010 | 08:22 PM
  #60
hatchback virgin's Avatar
Default Fuel Pump Problem
Have you found the root cause to your problem yet? I am going through the same problem with my 95 honda civic ex auto transmisson.
wkhan69
Aug 9, 2009 10:08 AM
SirTealingstonThe2ND
21
Dec 5, 2007 02:07 PM
xbrownieboy
Nov 6, 2007 04:56 PM
jomo
Sep 29, 2007 04:11 PM
seriously_furious
Aug 14, 2006 08:49 PM
