Need help! car wont start
Old Feb 2, 2007 | 07:00 PM
birdmane's Avatar
Default Need help! car wont start
I bought 2 91 civic HB the other day and 1 needed a new pressure plate so i put in a stage 2 racing and while i was at it I put in a rebuilt Si tranny. I finaly got it in today and drove the car around the block and it was quick . So i drive over to pick up a co worker stop the car and then it wont start back up not sure what happened. i thought it could be gas so i pushed it to a gas station and filled it up the car still wouldnt work so i pushed it home and checked spark (good) then while i was at it i replaced the distributer and put in new plug wires, then i also replaced the fuel pump and batery. im about to replace the starter, the car tries to start but just doesnt does anyone have any help or ideas they can offer
Old Feb 2, 2007 | 07:10 PM
Red Hot Rider's Avatar
Default RE: Need help! car wont start
If it tries to start, it's not the starter.
Old Feb 2, 2007 | 07:30 PM
Tater's Avatar
if it just sounds like your crank is spinning then it is the timing?
Old Feb 2, 2007 | 07:57 PM
kinosh's Avatar
Replace the main relay. I have a 1992 LX and had the same problem. The relay is about $50-60 and located under the dash, just above the hood latch.
Old Feb 2, 2007 | 08:04 PM
birdmane's Avatar
how would i go about doing the timming? im about to check that relay right now ill let you know how it goes.
Old Feb 2, 2007 | 08:13 PM
kinosh's Avatar
Open up the relay and check to see if any of the soldered joints are cracked.If you have a soldering iron, re-solder those joints that look bad.
Old Feb 3, 2007 | 05:38 PM
birdmane's Avatar
well i checked the timing and that wasnt it so im bout to check the relay now ill let you know how that goes
Old Feb 3, 2007 | 05:45 PM
fglaustin's Avatar
i did this one - very common.
http://techauto.tripod.com/mainrelay.htm
but i did not do the solder sucking part
Old Feb 3, 2007 | 05:54 PM
fglaustin's Avatar
Old Feb 5, 2007 | 12:12 AM
birdmane's Avatar
i checked the timing and i dont beleive thats it i also checked the spark plugs and the3rd one was covered in oil so then i checked the compression and these were the results
#1 135
#2 120
#3 140
#4 120
Im not sure what this means hopefully someone can help also my cuzin said its not the main relay so does anyone have any other ideas i still cannot figure it out thanks.
...NEED4SPEED...
Apr 20, 2010 03:55 PM
bmelloh
May 16, 2009 08:01 PM
n8te81
Feb 28, 2008 11:26 AM
gpacheco101
Jan 23, 2007 05:29 PM
gpacheco101
Jan 18, 2007 07:15 PM
