Need to know! I bought an engine and
Old Dec 23, 2011 | 08:24 PM
mpklkj's Avatar
Default Need to know! I bought an engine and
THE TIMING BELT BROKE ON IT SO THE GUY SOLD IT TO ME FOR 200 BUCKS.
ITS A D15B7 OUT OF A 95 CIVIC DX.
I NEED TO KNOW IF THE PISTONS HIT THE VALVES AND RUINED IT.
I SPUN THE MOTOR OVER BY HAND A BUNCH AND THERE WAS NO NOISES OR ANYTHING WAS REALLY SMOOTH.
LET ME KNOW ASAP!
thanks(:
Old Dec 23, 2011 | 09:51 PM
droopy128's Avatar
Better off replace with another used motor (faster), or you can take out the head and do it the long way.
Old Dec 24, 2011 | 03:46 AM
Just because it spins freely doesn't mean the valves aren't bent. The only way you can know for sure is to pull the head off.
You bought an engine with a broken timing belt for $200? Sorry, but that's not a great deal. I'm selling my old D16y7 for $150 and it ran when pulled.
Old Dec 24, 2011 | 03:48 AM
You can leakdown test the cylinders. Put a timing belt on and rotate the engine so the valves in the cylinder under test are closed. Apply air pressure through the spark plug hole and make sure it doesn't blow out through the intake or the exhaust. Or with a transmission and starter attached, you could compression test it out of the car.
offbeatcivic
Apr 11, 2007 08:05 PM
Colby Day
13
Oct 1, 2006 10:10 PM
Rockstar
Apr 14, 2006 03:26 AM
Fran
Dec 11, 2005 07:54 PM
