Noises
Old Feb 17, 2006 | 07:25 AM
san's Avatar
san
Default Noises
At first, my car would make noise everytime I would move the steering wheel. I thought it was my CV Axle because it needed to be replaced. After replacing it, the noise went away. Lately, that noise has came back making it even louder. I took a look in that general area (driver side) and see that a boot is ripped, not the CV Axle. I beleive it is the rachet pinion? I am not sure, and I am trying to figure out what it may be. I think it is attached to the steering wheel. Anyone might know what that is called?
Old Feb 17, 2006 | 09:30 AM
joey's Avatar
Default RE: Noises
there are rubber boots on both your rack and pinion and your cv joints. there are two cv joints per axle, inner and outer. they are covered by rubber boots, which are known to rip open on hondas. when this happens, dirt gets in, the grease gets out and your cv joint is no good. your axles go straight from your wheel hubs into your tranny, on both sides. there is a cv joint directly behind each wheel hub, then another on the other end of hte axle, where it enters your transmission. If it is one of these boots, then it's your cv joint and you're better off just replacing hte entire axle. a little further back (toward the firewall) is your steering rack.... there are rubber boots on this too and i believe they cover your inner tie rod ends. which boot on your car is ripped. also can you describe the noise? clunking at slow speeds and in turns is a cv joint. if there's a problem with your rack and pinion or your inner tie rods, i believe you'll just experience excessive play in your steering.
Old Feb 17, 2006 | 05:02 PM
san's Avatar
san
Default RE: Noises
my cv axles and boots are fine. it is the rack and pinion boots that are broken. That area squeaks really loud like there is no grease there. Do i have to replace the whole thing or just regrease and get new boots for the rack and pinion?
StifflersMom
Dec 18, 2005 07:38 PM
nemo
12
Dec 4, 2005 01:20 AM
toby
Jun 19, 2005 10:11 PM
nwhite82
Dec 5, 2004 04:53 PM
superflycivic
Sep 24, 2004 01:41 PM
