oil filter issue
Old Jun 12, 2009 | 06:52 AM
lilrootrx7's Avatar
Default oil filter issue
I recently changed my oil and it has been leaking a bit. We found out that when I pulled off my old filter, the old oring stuck to the car so now there are two there causing the leak. Would it be any bit of a good idea to just pull off the filter and fix it or should I do the whole drain oil from the drain plug and start fresh. I changed the oil 1000miles ago.
Old Jun 12, 2009 | 07:19 AM
Just pull off the filter and the extra oil ring, reinstall, and top off with oil.
Old Jun 12, 2009 | 07:23 AM
Don't drive at all till you fix it, as the second ring can blow out at any time, causing all the oil to run out and engine failure.
Old Jun 12, 2009 | 08:38 AM
lilrootrx7's Avatar
if I go and pull off the filter, how much of a mess will that make with oil coming out?
Old Jun 12, 2009 | 08:55 AM
No more oil should spill out than typically does when you change the filter for an oil change.
Old Jun 12, 2009 | 09:24 AM
lilrootrx7's Avatar
very excellent! thanks a lot buddy, really appreciate the help
mudhenFUF
Jan 16, 2023 08:43 PM
WILMER007
Oct 14, 2009 07:42 PM
Seafoamgreencivic
34
Aug 12, 2008 09:30 AM
oilltd
Jun 10, 2008 04:06 PM
