Outer CV joint removal
Old Oct 17, 2010 | 10:37 AM
zerojett's Avatar
Default Outer CV joint removal
Hello,
I am searching right now for how to do this... And have been looking for a while.
The outer joint is a ball and cage type, and the clip is on the inside of the joint. How am I supposed to separate this???
I know it is easier to replace the axle, and I found a thread about it... But I have the boots, and the axles off of the car. If anything, I am doing it for the experience.
Old Oct 17, 2010 | 02:44 PM
maachan513's Avatar
It has been more than 10 years since I had done this kind of job so ,,,,,,,I think you need to disassemble inner joint to slide out outer boot. I remember the retainer ring was bear to remove for the limited tools I had back then.
I also remember positioning outer joint at extreme angle and popping the ***** out and such,,,,
How did I do,,,,??
Getting old is not fun.
Old Oct 19, 2010 | 06:56 PM
droopy128's Avatar
You would just knock it off with a hammer.. careful tho.. need to bend down joint and not to hit the bearing and retainer, but would rather replace the whole axle..
Old Oct 20, 2010 | 01:33 AM
Officially, the outer joint is not to be disassembled in the field. I suspect the factory uses a machine to force them. The price of rebuilt axles is low enough it's really not worth messing with the joints even just to redo the boots.
Old Oct 20, 2010 | 11:18 AM
zerojett's Avatar
ended up taking off the "dynamic damper" and sliding the outer boot off of the inner joint end... This is just a temp fix, and I did it for the experience of it. I will end up buying new axles soon enough, but it was fun to learn although messy.
laack
Feb 14, 2010 08:33 PM
evictor99
Dec 5, 2009 01:00 PM
civicpsycho
Jun 27, 2008 03:28 AM
dfdon
Jun 25, 2007 04:16 PM
anthony_delprete84
Aug 9, 2006 09:11 AM
