Overheating... Need Some Help
Old Jan 3, 2012 | 11:17 AM
  #21
Jump the fan switch and test drive with fans running all the time, if it still overheats it's not a fan problem.
the fans come on because the coolant leaving the radiator is hot. This implies that there is coolant circulating from the engine through the radiator, which requires the following:
system full- if dry there will be no circulation
thermostat open -- if stuck closed again no circulation.
radiator not clogged-- that can be ruled out now since you have a new one.
Old Jan 3, 2012 | 11:57 AM
  #22
darkside's Avatar
Could you elaborate on that one a little bit? Are you asking if the system has enough coolant?
Old Jan 4, 2012 | 02:14 AM
  #23
If there is a pocket of air, the coolant doesn't circulate well because the water pump can't move air. It really sounds to me like there's a slow leak in the head gasket. Get the system as full as you can then let the engine cool off fully. Next start the engine with the radiator cap off and rev it up. If you see bubbles steadily coming out, the head gasket is leaking. A severe case will have coolant surging out of the radiator.
Old Jan 4, 2012 | 06:26 AM
  #24
darkside's Avatar
Yeah that's what I've been thinking, just been hoping for someone to tell me otherwise. It's really strange, it overheats when I'm idling, but as soon as I hit higher speeds, the temp gauge goes back down.
Kyle_2015
Mar 29, 2015 11:49 AM
2000Ex
Aug 18, 2009 02:15 PM
JakeyMan07
Jul 6, 2008 09:12 PM
KS200
15
Oct 17, 2006 02:49 PM
trebor_2005
May 19, 2006 01:40 AM
