Overheating and smoke
Old Jul 18, 2008 | 04:17 PM
Sow Lancelot's Avatar
Default Overheating and smoke
I have a '95 Civic on which I just had the head gaskets replaced. It was leaking coolant. Been running a little hot but today it spiked. Oil was low so I added enough to register properly. Runs fine for about 20 minutes then I hear a cross between a click and a flutter and smoke billows from the tail pipe. No leaks, no smoke from under the hood.
Any ideas. Could it be a pressure issue rather than coolant?
Thanks.
Old Jul 18, 2008 | 04:21 PM
Default RE: Overheating and smoke
Unfortunately, if the exhaust smoke is white, then you are burning coolant, meaning that either the head was warped when the new gasket was installed or the gasket was not installed properly.
Old Jul 18, 2008 | 04:35 PM
It's kind of a bluish white. Is that still coolant? When they replaced the gasket they supposedly ground the head flat.
Old Jul 18, 2008 | 04:49 PM
Bluish smoke would indicate the burning of oil in the cylinder(s). This could come from worn piston rings, leaky valve seals, or a bad head gasket/head. Do wet versus dry compression tests on the cylinders. The wet test will yield higher compression than the dry one if the rings are bad.
Old Jul 19, 2008 | 05:00 PM
The smoke will smell like antifreeze if it is coolant related.
d-leo
Dec 11, 2013 09:40 PM
Sow Lancelot
Jul 20, 2008 09:31 AM
vektor
Jun 17, 2007 07:20 PM
trebor_2005
May 19, 2006 01:40 AM
snosurfa7
May 5, 2006 08:21 AM
