PROBLEM with starting ?!?
Old Aug 23, 2007 | 02:47 PM
Safety_Driver's Avatar
Default PROBLEM with starting ?!?
Yesterday for first time for the last three years my Civic '94 LX(D15B7) did not start,
and I had to take my cousin's car.[]
The same day, but in the evening the car started?!?
A friend of mine has Del_Sol and said, that experienced the same problem even after replacing of spark plugs nad wires and distributor cap.
What should I do?
This happend only once, but there was no reason?
What do you suggest guys?
Thanks in advance!
Old Aug 23, 2007 | 06:51 PM
gwl's Avatar
gwl
Default RE: PROBLEM with strating ?!?
Did it turnover when you had the problem?
Old Aug 24, 2007 | 05:28 AM
Turnover what?
No it didn't, everything was fine.
Old Aug 24, 2007 | 06:35 AM
gwl's Avatar
gwl
I meant, did you hear your starter?
Old Aug 24, 2007 | 06:14 PM
Yes, everything was fine.
The starter is fine,the battery is fine too.
I was driving yesterday and today and outhere is very wet and humid, but no problems.
It should be somtething with the ignition, maybe wires or distributor cap, I don't know?!?
Old Aug 24, 2007 | 09:39 PM
AgentofDarkness's Avatar
When it doesn't start, pull one of the plug wires and attach a spark plug to it. Crank the engine over and check for spark. If you see spark, then you have a fuel problem. I actually have this same problem but I haven't gotten around to fixing it. I believe the problem will be related to the fuel system. First change the fuel filter if it hasn't been changed in a while. Check to make sure the fuel pump is actually turning on (listen for it) because overheating relays is a common problem with these cars. Check the fuel pressure regulator as well although a problem with the FPR might only occur when it is really hot out or the engine is still hot.
djt
Jun 21, 2008 07:48 AM
totenkopf
May 31, 2007 03:36 PM
Expando1
Aug 12, 2005 08:34 PM
terraeisa
Jul 14, 2004 10:23 PM
raphn
Jun 14, 2004 02:07 PM
